1 - 8 of 8 Posts
Discussion Starter · #6 ·
Originally Posted by Crazy9000
You can also drag them if they are physically in the wrong spot (if screen 2 is on the other side, just drag it there and windows will change it).
when i do so they just change spots not numbers
Originally Posted by d-block
I think that if you click on your main monitor and select use this as primary it will switch. If not, it really doesn't hurt anything having the numbers like that.
it switches which one the start menu is on but its the same numbers... and with the numbers like that i started running into problems on steam and when trying to watch blurays
1 - 8 of 8 Posts
