Hello all, NEEDLES TO SAY, I am very new to this, but trying my hardest to figure all this out. I have a script right now which actively removes all empty rows from an entire workbook. But I'm hoping someone can assist is narrowing this down to a single sheet within that workbook.
function removeEmptyRows() {
SpreadsheetApp.getActive()
.getSheets()
.forEach(function (s) {
c = 0;
s.getRange(1, 1, s.getMaxRows(), s.getMaxColumns())
.getValues()
.forEach(function (r, j) {
if (r.toString()
.replace(/,/g, "")
.length == 0) {
s.deleteRow((j += 1) - c)
c += 1;
Ideally I would like for this to remove only blank rows on one sheet within my workbook called 'Racing Results'. The reason I'm need this, is due to how the spreadsheet is setup and having multiple rows merged together. So when I copy these results over to a different sheet, there are gaps between them and I'd like them removed. Here is the script I'm using to copy the data to another sheet.
function Copy() {
var sss = SpreadsheetApp.openById('18cl69Id4saI455wk__-PhvfxXZa7iWlQpoiRKqBz6bU');
var ss = sss.getSheetByName('Score Card');
var range = ss.getRange('A32:E36');
var data = range.getValues();
var tss = SpreadsheetApp.openById('18cl69Id4saI455wk__-PhvfxXZa7iWlQpoiRKqBz6bU');
var ts = tss.getSheetByName('Race Results');
ts.getRange(ts.getLastRow()+1, 1, data.length, data[0].length).setValues(data);
If not to throw one final monkey wrench into this colossal mess, I have been attempting to copy two different cell ranges within the same script and I feel like this isn't possible because only the latter one gets copied and the initial one is discarded. Here is the other copy script I am using which runs before the one above this.
function Copy() {
var range = ss.getRange('A1:A1');
In a perfect world, what I'm trying to get setup is the following. Above is a screenshot of the scorecard we are using. I am wanting to copy the Current Date (A1) to the 'Racing Results' sheet, then I want to copy the final score with the team names (A32:E36) and move them to the 'Racing Results' sheet right under it. Once that has been done, I want to remove the empty rows between the results because as of right now this is how it looks when copying over. (see image below)
Thanks in advance to anyone who is able to assist with any of this in any way shape or form.
