This kit works very well on Intel 1156.
On AM3 it works best on the 1:3.33 memory multiplier, the 1:4 memory multiplier tends to have issues with this kit.
...okay well they SHOULD be fine. Mushkin makes solid RAM.
Ummm I looked your board up and unfortunately Newegg didn't have more than this...
"Memory Standard DDR3 2133 OC" listed for RAM specs. Now I'm not 100% sure but is your MoBo backward compatible for RAM? Do you know the actual chip specs or is this what you have in your manual too?
I'm hoping this to be the case that it is indeed compatible with your system. Would hate to see anyone waste time waiting around only to get epic blocked.
~Ceadder
It's about the CPU and not the RAM. Early C2 Revision AMD CPU's do not like the 1:4 Divider (DDR3 1600mhz) while the C3 Revision CPU's ship with a better IMC (Integrated Memory Controller) that is much more stable with 1:4 and higher dividers.
Originally Posted by el gappo
What IC's are these using nick?
I think these are the Elipda Hypers.
The XP's and Black's used Micron D9's. While the Redline 2x1GB were Hyper's.
I was thinking maybe well binned bbse because of the ridiculously low price in comparison to other hypers
Would love to do a comparison vs the dominators
Not seen them properly overclocked on amd yet, would be really interesting from a pricepoint view if they work well and I would look a fool wasting £400 on corsair sticks lol
In regards to the divider issue, I have noted complaints about it but recently have been testing myself and with the dominators at least I'm finding the 1:4 is giving me the most headroom. This cpu in particular has a very weak imc and northbridge compared to the likes of my c2 sempron
But I can't complain. Piccies below. I think it's a board specific issue tbh, mainly the fxta :/
Some 1m.
Mushkin's always offered really good RAM at a lower price, compared to others.
Though, I'd definitely like to see it.
1 - 14 of 14 Posts
