1 - 3 of 3 Posts
hi,
I have abot 1000 songs that i would like to compress a little bit so they will fit on my 4 GB mp3 player, my problem is that all of my songs are in lots of folders and are not all one format, they vary from wma to mp3. what i would like to know is, is there a way that i could take all of these files, and convert them all into the same format without needing to move them all by hand into one folder and do all that long tedious stuff?
thanks!
The fastes way to do it is to DL itunes load all songs into there edit what format you want which would probably be mp3 and highlight all songs and format them. It will take some time but it will get the job done and put them all in a itunes folder. Make sure you select you want them organized in your itunes folers also.
pink
1 - 3 of 3 Posts
