Hi,
I'm having some really annoying slow downs in Modern Wafare 2. I have had a couple of problems before this, which might hint at the solution, so I'll quickly run through them.
I'm running 1920 x 1200, 2 x AA, settings maxed out. I use VSync.
1st: I torrented the game (with the best of intentions, as you shall see). I couldn't play Multiplay, obv, but the campaign played fine, albeit a little choppy in some sections (mainly the rio diginero sections, and some foresty levels). However all I got then was a drop in fps, still playable, but not ideal.
2nd: Happy with performance I bought the game. Installed into Steam no problem, but I had to call my isp to give me a public ip, so I could open my NAT and actually find some matches (incidently having an open NAT also stopped the 3-4 minute freeze-up on the intro logo/menu).
3rd: I still got the slow-downs in Estate, Favela, Rundown, Underpass and maybe others. This was a big problem in multiplay and since I figured my rig was capable of more, I did some research. Turned out to be because I was running XP, other people have said that going from XP to Win 7 has stopped slowdowns in the same maps. The problem also exists in cod4 (also in certain maps). Sure enough after installing Win 7 I could play the previously problematic maps at 60 fps constant. Again, it also fixed some slowdowns in cod4, which is nice.
4th: Now I have a new problem. Most of the time the game runs smoothly, it's always at 60fps (maybe 40/50fps in one or two parts of Estate still). But now I've started to get these pauses. And once it starts it comes thick and fast forcing me to leave.
Essentially it's the screen freezing (ambient sound continues, weapon sounds depend on whats on screen) when I move or look around, on some maps. I'm pretty sure it's a graphical issue, because if I look just at the floor and run around, the freezing doesn't happen. I don't really know what to try, I reinstalled ATI 9.11's and also installed the proper Realtek drivers for sound (not Win 7 generic).
This is the most annoying kind of problem, because the problem is not always there. It tends to start properly when I've played a few full matches. If I quit the game and start it again, I'm ok. But it can be random. I've uploaded a few Fraps frame times to show gameplay when I'm not having the freezing issue.
Also, these are all the mp maps. I'll put my performance situation next to them.
Afghan - Fine.
*Derail - Some pausing.
Estate - Sometimes fine, drops to 40fps in some parts (more demanding map?), but pauses a lot 9 times out of 10.
Favela - Fine.
Highrise - Fine.
Rundown - The worst, basically unplayable.
Rust - Fine.
Scrapyard - Fine.
Skidrow - Fine, but a little pausing once I think.
*Sub Base - Some pausing.
Terminal - Usually fine, but the pausing problem has happened a couple of times.
Underpass - Pausing.
Wasteland - Fine, but only testing as private server on my own for maybe a minute, after uping to Win 7.
*I get confused between these maps. I think 2 out of 3 of the snowy maps (right?) can start pausing.
I've removed the maps I haven't tried yet.
Thanks for reading, any help is really appreciated,
safe
