MW2 Single Player - Unavailable
1942 Views 15 Replies 7 Participants Last post by  iscariot
Steam is telling me the single player is temporarily unavailable.. What the hell is this? I know this is a steam game but why should they stop me playing SP when I chose to?
1 - 16 of 16 Posts
with a steam game like... hl2 i only get that when im not on the net, and obviously ur on the net, try restarting steam and see what happends, also make sure ur not in offline mode
well that has baffled me :| single player ot working but multiplayer working... its usualy the other way around :S, try doing an integrity check (cant remeber how to do this now)
does steam have to recognise ur crossfire ? isnt it the games on steam that have to recognise it or is there something im completly missing :S
You can verify this by right clicking on the game name under the "My Games" tab, going to "Properties", selecting the "Local Files" tab, and pressing the "Verify integrity of games cache..." button. Good luck, if your not able to connect, and the game is able to verify integrity I'm not sure what to do. Wait a few hours and try again, if this comes back positive you'll likely need to reinstall, and I'm not sure if SP saves are saved.
I had a look at my system settings according to steam and it was only showing one card. This is the first time I have used steam so not sure if that is normal or not. Both cards show up everywhere else.
If it were me, I would delete the clientregistry.blob in my steam folder. Then I'd restart steam.
Ok so it needed to re-acquire files, its good to go now. Anyone got any ideas why steam doesn't see both my GPUs?
Anyone else noted that it doesnt see xfire or SLI?
Originally Posted by Sanders54
Your 4890 should max it easily anyway
Yeah it does, but I have two cards and I'd like to use them
Bedsides my real concern is that should I ever play a game on steam that requires my Crossfire setup it wont use them..
That would be a crime
JTM668:
No Im not in Russia but as far as gaming is concerned Im very close.. Im in Australia where people over the age of 15 dont play games....:swearing:
1 - 16 of 16 Posts
