641 - 660 of 677 Posts
Is that the thing that is sticking out of the mouse or the pins?
the plug on the mouse end of the cable, the white housing has a catch for each crimp where you can see metal through the side of the connector. you can pry that back with a razor blade and take the crimps out, then put them back in in a different order. Though be careful, because it can be easy to tear the wire off of the crimp.
Bought it out of curiosity. For the record, I never used the MX518 back in the day and therefor it took me 2 hours to get used to the ledge on the right (1-3-1 just doesn't feel right to me), but now it doesn't bother me anymore. But as soon I went ingame, I noticed the insane performance. I'm not sure if it's the hero sensor, shape or click latency, but this mouse owns in CS:GO. Making small adjustments when aiming was never easier before. I compared the mx518 and g403(non-hero) multiple times and it felt like the g403 had way higher physical click latency for some reason (hard buttons, idk). The mx518 also gives me more control without the dumb g403 hump and feels rather light for the proclaimed weight. Sure, the mouse wheel, cable and silver material top could be better, but that's a trade off I gladly make. I can only recommend this mouse for competitive FPS accuracy freaks.
nice to hear someone else discovering this mouse.
I'll post up some more pictures of my newly paracorded and slightly more weight reduced version tomorrow.
Ended up ditching my MX518 legendary, to many issues, some small and can be fixed, others not that easy. Buttons to stiff, DPI levels are off compared to other mice, sensor fealing weird, hyperglides dont fit in height etc etc. As i said some of them are pretty easy to fix. After having owned all mice with this shape for god knows how long, mx500-510-518 G400-400S and now the MX518L. Going to step back to the G400s for now and try out glorious model o and maybe the latest zowie EC batch again.
Its just going to be my opinion, but i dont think logitech did that good of a job on the legendary, main reason being the buttons are way to stiff even after being worn in, the D2FC-7N 20m used in this mouse isnt what they used to be.
Hi ppl. Some days ago I tried to do a fix to my old MX518 and ended killing it after a really long time of good service. I was never a big fan of it's design and changed my mice many times but always ended going back to the MX518 after a while due to different reasons and the MX518 was always there working fine. In fact it was "dead" once but I had a bad MX300, opened both and changed cables, so the MX518 was back with the MX300 cable. But after my bad fix some days ago, I really killed it.
I had many other over the time, like MSIE 3.0, MX300, G300, G303, G102/203, G402, G600, G9X, G403, SS Rival 300, Cougar models, etc. But since I'm in another country now, I brought only the one I could really trust, the MX518, so when it died, I had no mouse to use.
After a little research I decided to buy the Glorious Model O at a local shop nearby just because it would be grab and go, no shipping wait, and it was the only decent mouse available around. I expected it to be a bad design for me but in fact it's worst, it's unusable because I can't find a grip. So I used a 3M Dual Lock tape to create a grip and was using it "fine" for a few days. Looks funny but works and the mouse is really, really good. I am still amazed about it's sensor being so responsive compared to what I was used, the MX518. It's much snappier, and I'm a flick/drag shot player using mostly snipers, so I felt instantly what I was missing with the original MX518. Once I could hold the mouse almost properly, the tracking was a night and day difference for me, something I felt before when I first tried the G303 after using for years MX300/MX518/G9X/G402 but I wasn't remembering because now I was using only the MX518 for the last 2 years. And yes, the difference is huge. Glorious Model O tracking just feels right.
But I wasn't happy with the grip and my solution with it, so I decided to find something else. I could find the new MX518 Legendary used like new from a local ad and the guy was selling old stock Func mousepads too. Since I loved the 1030 backthen in CS competition between 2001 and 2002 and I wanted the rough surface again, I made an offer and could grab the MX518L and the Func F-Series F30.R.
Considerations about the MX518L:
- It's the exact same design, even the QC problems are the same;
- My right click and side buttons have some pre travel, somewhat annoing;
- Wheel is the exactly same, it misses some clicks but will last forever so it's ok;
- DPI+ button is ok, but DPI- and the shift button are really bad. I had these 3 removed from my previous MX518 since they were useless for me and may do the same here;
- Cable is good, but now with a stress relief, so that's better;
- The 3 mousefeet design is somewhat wobbly, my original MX518 was the 5 little feet design and it's perfect, stable and still glides amazingly. I never changed the feet;
- The 5 mousefeet design seems to be better for me, and it wasn't required to destroy/remove the mousefeet to open the mouse;
- Logitech software was used just to set the settings to the internal mem and was uninstalled not to be installed ever again;
- The overall feel of this new MX518L is somewhat hollow, I feel like my original was "firmer" overall, but I opened it many times, fixed all the button pre travels and removed completely the dpi buttons and their mechanism.
But the tracking felt strange, I don't know why. I played some matches and after a while I was feeling like it wasn't with me, but "behind" my movement, like if it was a little, very little, but still, delayed. I was puzzled about this and did some research to find most reviews praising the Hero sensor. But here I read posts saying the DPI wasn't correct. So I've set the DPI from 800 to 850 and tried again. I believe that making it this little faster improved my sensation, but still, I think it's not with me, but behind me, very little delayed compared to my movement. It's tracking perfectly, it does what it should do, but it feels like it does after me, not with me, not real time. So after 2 days playing only with the MX518L I decided to try again the Model O (set to 800dpi) and yes, it felt snappier even being a little slower due to the lower dpi. But it feels like it's ready, snap, real time. My MX518L somehow doesn't. I remember I immediately loved how the G303 tracking felt besides the grip, but not the MX518L even having the best grip.
So, my questions are, if anyone bothers to help:
- Am I crazy or the Hero sensor isn't on par with the 3360 sensor?
- Would the Nixeus Revel Fit be a better choice compared to the MX518L or it's 3360 implementation (or anything else) is bad?
- Are the MX518L internals compatible with the old shell? If I could get rid of the wobbliness it would be great already.
Thanks in advance for any help?
Mouse addict
Nixeus Revel Fit has the same internals as the regular Revel w/ the latest firmware, so it's a standard 3360 w/o any issues worth mentioning (Holtek MCU however).
here is some feedback for logitech, should they read it.
1. the grip of the rough plastic is much inferior to the coating of mice like the g403. the g403's coating also comes closer to the rubber the original 518 had, so why not use that one?
2. the buttons are way too stiff, again not up to par with g403 quality. please use the soft and springy classic omrons again.
3. biggest disappointment: the feet are a big step back, big uneven feet just glide way worse than small ones. why? because the 518 is a palmgrip mouse, which means the weight of your hand will increase friction and friction points are different and bad with these large, edgy feet compared to the small round ones, especially when you rest your hand on the mouse. the small feet version of the mx518 was always superior.
for the me feet ruin the smoothness of my tracking and make smaller movements much harder and I believe they are the culprit for when anyone says their tracking or their micro adjustments felt off with this mouse.
the lod on my mx518L seems to be kinda buggy, sometimes it happens to be over 3~4 dvds when i lift it from the pad, it happened on my havit mp830 speed and zowie p-rf, i don't have other mousepad to try
In my experience, I seem to be more accurate with the 3366 in the G403 than the G Pro Hero 16k wired. The 3366 in the oringinal G Pro wired (the tiny mouse) was inferior to the G403's 3366, so Logitech is just not consistent with their 3366 sensors from mouse to mouse. I don't really want a big, more palm-style mouse, which is the only reason I don't use the 3366 G403 as a main.
Another thing to note is, I've used FOUR G Pro Hero 16k wired, and one of them tracked great, one almost as good as the first, and the other two seemed to be a lot slower and I couldn't play as well with them. Not sure if that's all due to DPI variance or what. I don't know what the common DPI variance on mice is nowadays, but if it's a range upwards of 20-40 or so, that would make an enormous difference whether you like a mouse or not.
Have you looked at the lens? Sometimes there are much dust on the lens and the LOD becomes very high. Wipe it regularly and it will be fine.
No LOD issue on GSR or Puretrak Talent. Replace your unit.
As for the HERO vs 3360 debate:
Technically, the HERO should be superior, as it has a continuously variable Framerate (or a lot of "preset" framerates) to track accurately at any speed without oversampling too much, where the 3360 would only have a few.
But it would also make the sensor harder to "master" so to speak because there is more variance.
Here is more info on the HERO. https://blog.logitech.com/2019/03/29/anatomy-of-a-hero/
I believe the default DPI on the G MX518 is 1600?
Back in the days it was recommended to stick with the default DPI of a mouse and adjust sensitivity accordingly in Q3/QL/CS/ET/RTCW/...
Does this still apply or can I go back to 800 DPI (or 840 DPI which should translate in the 800 DPI of any other mouse)?
Does this still apply?
Nah the new sensors for the last few years don't have a native DPI so anything you want to use is fine. I think most people stay between 400 and 1600 though.
