My 1000HE
2449 12
You want pics, here are pics (albeit, crappy pics)
Enjoy the porn
1 - 13 of 13 Posts
SOOOOOOOOOO SEXXXXXXXXXXXYYYYYYYYYY Must resist on Netbook buying....waiting for more epic tech in them.....must wait....ugg...why do you make this so hard.
wow.. i want so bad...
Discussion Starter · #11 ·
Originally Posted by subliminally incorrect View Post
nice 1000HE. looks like mine, but me thinks that you hath loaded win7 on it?
how's it run compared to xp and hows the battery life?
nope, just xp with a custom mstheme
battery life is pretty good, i haven't had the chance to break it in yet, but from what i can tell..expect ~7 hours of battery life with power saver on and screen at 30% brightness (pretty bright), wifi on, and surfing the nets
If I were you, I would try out battery doubler to increase battery life. It usually gives you around 30 minutes more. The biggest thing that I've seen it does that isn't easy to implement manually on the fly is disabling unused ports. You may be surprised by the amount of power drawn by idle I/O ports.
Discussion Starter · #13 ·
I will have to check this out
Thanks!
1 - 13 of 13 Posts
