I have a 2600k overclocked to 4.5G @ 1.28v
and when running LinX, Super Pi etc, the benchmark was obviously slower than other similar setups.
Brief information of my rig
Intel 2600k
Corsair H70 cooler (with 2 Gelid Wing 12 PL)
Gigabyte P67A-UD5-B3
4GB x 4 Corsair Vengeance DDR1600 running @ 1600 9-9-9-24-1T
Asus GTX 480
Intel X25-M 120GB G2 Harddisk
4 SATA 7200RPM Harddisk
Corsair HX850 PSU
now, this is my result(this is 4.7G overclocked, because I lost the capture of 4.5g)
and this is others result(he even use lower end 2500k)
my rig 20% slower than his in the Gflops.
my rig run very stable, no BSOD no Halt no anything after Prime95, Linx, IBT and OCCT stress.
about super PI 1M, I tried to run @4.5G earlier, my result was 8.437
while other people overclock to 4.5, most of them got like 8.1xx
and now at AIDA64 benchmark, in Memory tests, my rig lost to a stock speed 2600HT.
The CPU test my rig was faster than the 2600HT, except one test the CPU
AES
my bios overclock config is like this
BLCK 100.3
Multiplier 45
RAM Voltage 1.54
Vcore 1.28
QPI/VTT 1.2
CPU PLL V 1.74
C1E, EIST and other power management are disabled
Spread Spectrum disable
Ram PC1600 9-9-9-24-1T
this is pretty much what I've configure my overclock.
I've heard when you overclock and your Vcore not enough will cause performance drop, so I tried to increase the Vcore to as high as 1.425v
but the performance is exactly the same.
I am very worry if my CPU or RAM or Motherboard is detective or I did anything not good enough for the overclock,
experienced user can you please help me ? Thanks!
Intel 2600k
Asus GTX 480
Corsair HX850 PSU
AES
BLCK 100.3
Multiplier 45
RAM Voltage 1.54
Vcore 1.28
QPI/VTT 1.2
CPU PLL V 1.74
