My 360's hardrive just failed...
1161 Views 23 Replies 16 Participants Last post by  Lord Xeb
D: Not cool man... I got the e68 error which means *** hard drive.
1 - 20 of 24 Posts
remove your hard drive and re attach it again, worked for me when i had that error 3 weeks ago
Did 4 or five times now...
Do you break everything?
No. This thing just failed on its own.... Personally I think I can cursed or something.
New HD for 360: $50
New 360: $400
Getting banned for fixing it yourself and not paying M$ to fix your 360: priceless
Yep, if you do not do it right... I am just going to get a hard drive.
Originally Posted by Villainstone
Well I am not sure what kind of HD the 360 takes but in case you are looking I have an 80GB laptop drive.
It has to be a certain part number blah blah crap.
Thanks.
hey...I fixed my xbox hard disk simply by removing it and throwing it on bed..
and it just simply works till date..no problems at all..(just done it 2months back
theres ways on doing the hard drive mod, im running a 320GB on my Jasper 360. Im going to play it safe and not post on how to do it. im not sure on overclocks policy. I have had it for 4 months now without getting banned.
did you have a sexy time with it?
I'm pretty sure that MS will fix it for free if the seal isn't broken. If you don't want to send it in I would take it apart and disconnect all the cables then plug them back in, it could just be a bad connection.
effing microsoft man, i was planning on getting a 20gb hard drive and putting in it a 500gb one, so much for that happening
Seal is broken
Originally Posted by Lord Xeb View Post
Seal is broken
Could try connecting it to a pc to see if its possible to get the data off... Unless its dead as a doornail.
Firmware on the Xbox HDD is locked. Can't be seen in an OS environment.
1 - 20 of 24 Posts
