I already have it disabled. I had to disable it to use msi afterburner in the first place.Originally Posted by Ken1649;15290872
If you are using Afterburner to overclock, disable ULPS not to interfere with PowerPlay and throttling down to stay within power draw limit set.
To disable ULPS:
1. Go to regedit (start > search programs and files > "regedit")
2. In drop down menu > find file > type "enableulps"
3. For ALL instances (keep pressing F3) change the "1" value to a "0".
4. Restart PC.
Increase the voltage by 10mV and test again. If it doesn't work we try something else.
Originally Posted by Ken1649 ![]() What voltage applied to both cards now? Go to CCC > Overdrive > Power Settings +20% and run the test again. |
You can use Overdrive PowerSetting +20% but it will reset it to default 0% in the presence of Afterburner every PC restarts.Originally Posted by doc2142;15290943
I thought I can't use overdrive with msi afterburner?
If I do close out msi burner and use overdrive my scores is normal. However, when I do have msi afterburner open, not even ocing my cards just sitting there monitoring my score drops by 3k.
