1 - 15 of 15 Posts
yes i have a new pci-E graphic card a 6800XT 128mb.<br />
<br />
i recently got it overclockt its stock at 350/750 and i overclockt it for standart 2D 450/820 and performance 3D 513/820 <img src="/images/smilies/cool.gif" border="0" alt="" title="Cool" class="inlineimg" /> if i go any higher with GPU core i get flocks and if i wana go higher with memory it says it cant do such high memory speeds <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" /> and the temps are 52 idle and when playing very high 3D games it says max like 1 hour of playing 77 C <br />
<br />
so what you guys think of my overclock any sugestions :S
That is a nice achievement, what about any benchmark like 3dmark? The temps are a bit high i would say, why don't you go for a good zalman vf700? it would keep your temps like 10° c lower than stock cooling <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
<tr>
<div>
Originally Posted by <strong>Qwin</strong>
</div>
<div style="font-style:italic">yes i have a new pci-E graphic card a 6800XT 128mb.<br />
<br />
<br />
so what you guys think of my overclock any sugestions :S</div>
</td>
</tr>
</table>
</div>maybe a better cooling system on or around your graphics card?My overclocked BFG 7300 GS is 48C at idle and 51-53C is usually the highest it ever gets after playing some intense 3d games.
dont bother raising the 2d clocks you dont need the speed, it will just make more heat while at the desktop , you sure you got it to 1650mhz on the ram ?<br />
<br />
ive never seen an overclock like that on any of the 6 series
<tr>
dont bother raising the 2d clocks you dont need the speed, it will just make more heat while at the desktop , you sure you got it to 1650mhz on the ram ? ive never seen an overclock like that on any of the 6 series
</td>
</tr>
</table>
</div>There's no way to obtain 1650 Mhz on a 6800xt on the ram, he meant a 410, 2x cause it's ddr <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /><br />
I agree with the 2d clocks, there is no need to do such a thing since your vcard will be hotter than normal
<tr>
<div>
</div>
<br />
i recently got it overclockt its stock at <b>350/750</b> and i overclockt it for standart 2D 450/820 and performance 3D 513/820 <img src="/images/smilies/cool.gif" border="0" alt="" title="Cool" class="inlineimg" /> if i go any higher with GPU core i get flocks and if i wana go higher with memory it says it cant do such high memory speeds <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" /> and the temps are 52 idle and when playing very high 3D games it says max like 1 hour of playing 77 C <br />
<br />
</td>
</tr>
</table>
</div>750=1500ddr on the mem? You gotta be kidding me. I don't know any 6800xt comming 1500 stock on the memory.
<tr>
</td>
</tr>
</table>
</div>ddr3 doesnt run that slow <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
so he is either running 410mhz ( so 820mhz effective )<br />
<br />
or he is running 820mhz ( so 1640mhz effective )
He didn't really say what kind of memory it mounts, guess it's ddr2 but not sure
Discussion Starter #9
did i say it was at 1650 mhz with memory i sad 820 <img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" /> <br />
<br />
and here is a screenshot <img src="/images/smilies/cool.gif" border="0" alt="" title="Cool" class="inlineimg" /> <br />
<br />
<a href="http://img267.imageshack.us/my.php?image=6800xtoverclockmx0.jpg" target="_blank"><img src="http://img267.imageshack.us/img267/3981/6800xtoverclockmx0.th.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></a><br />
<br />
ITS DDR MEMORY NOT DDR2
from that screenshot, yeh your running it at 820mhz effective<br />
<br />
so the real speed is 410mhz ( ddr820 = 410mhz )<br />
<br />
<br />
is the 6800xt running ddr2 or ddr3 ram ?
Discussion Starter #11
Just Ddr Not Ddr2 Or Ddr3
Why don't you try to enable the locked pipes via rivatuner or coolbits, that would give you a nice boost in performance
What make is the card
Discussion Starter #14
yeah i heard about it but how can i do it can you gimme a guide or some help how to do it i have rivatuner but i can only overclock with it but how to unlock :S<br><br>
NV41 chip if thats what you ment
Here is a guide on how to unlock the pipes<br><br><a href="http://www.hardforum.com/printthread.php?t=841145&pp=40" target="_blank">http://www.hardforum.com/printthread.php?t=841145&pp=40</a><br><br>
The max you could get off a 6800 is 16 pipelines and 6 vertex, but it's not 100% guaranteed you will be able to cause maybe some of them may be damaged
1 - 15 of 15 Posts
