1 - 20 of 119 Posts
First off, thanks to everyone here for sharing their builds and knowledge, you all made this so much easier to do!
Without further ado, here it is.
Starting Point, Stock cooler, yuck!
700
Pile o' parts
400
Lower drive bays removed, ready to cut opening for EX240 rad.
400
240 mounted
400
Naked video card
400
Ram sinks and GPU block installed
400
Garbage!
400
The beating heart of the beast
400
Cpu and RAM blocks mounted
400
Res and fan controller
400
What's this for?
400
This!
400
Much cursing later, time for filling and leak testing!!
700
Up and running!!!
700
Res with Mayhems blue dye, kill coil, and a blue led underneath for effect
400
EK Bridge
400
One more shot
700
Thats all for now. The Gpus and Cpu idle around 38 degrees with fans set to 750 RPM and load at 65 for Cpu and 48 for Gpus at stock clocks, with pump set at 23% duty and fans maxed at 1440 rpm.
In the coming weeks I plan on cleaning up the wiring and polishing/clear coating the copper tubing. That and I'm drooling at and Aquacomputer Aquero setup, but for now my wallet hurts so some recovery is needed!
Man! Impressive work with the copper pipes
Didn`know that this is legal
But looks very sweet and robust. God job sir!
that is beautiful!!
Discussion Starter · #13 ·
Originally Posted by UNOE View Post
Does the copper help convect heat ?
A little bit I assume, but I doubt enough to really make a difference in my temps. I mostly did it for the challenge and looks. I had never bent copper tube before, so for every pipe in the pc I bet I had two more bent up that went wrong.
Discussion Starter · #14 ·
Forgot pics of the drain port!
400
400
It's mounted in the front of the case, bottom left and hidden behind the front panel. I used a bulkhead fitting and can thread in a hose barb with hose running to a bucket, super easy!
Anyone drill and tap a fill port into an XSPC bay res, or know of a way to replace the stock cap for this? I have another bulkhead fitting and tube for a fill port but didn't realize the top wasn't a G1/4 on this res
Nice work. I am about to mod my 800D with copper piping too. That's 12mm? Where did you get the tubing. When you cut it, you had to sand down the edges right?
Discussion Starter · #17 ·
It is 12mm OD. I ordered it from coppertubingsales.com, they sell it in 10 meter coils for around $100 shipped, and I used most of it as I had more than a few screwups. I used a grinding drum and wire wheel on my Dremel to sand the edges down. If you dont the sharp edges will ruin the orings in the fittings. Also I used a Draper tubing bender part #72376 that came from ebay via the UK. I had to sand/grind some imperfections off the mandrels that were scratching the tubing pretty bad, but after that it worked great.
Thank you very much. Rep for you sir. I will be doing this after painting my 800D
. I will most likely contact you
Discussion Starter · #19 ·
You're welcome and good luck! Keep in mind that the bends you see are as tight as they get. I had envisioned them much tighter and closer to the blocks but the bender kinda ovals the tube along the bend. Also a few spare fittings for test fitting and possible leaks are very helpful. I had one leak at the top of the crossfire bridge and also cut the tube from the lower bulkhead to the lower rad too short and it would pop out when the case flexed while moving it. A quick rebend fixed it though, but I plan on draining the loop before moving the case in the future just to be safe.
MegaTechPC
OMG that rig looks amazing! I wish I could do copper pipes but that seems way too ambitious for me to try on my first W/C setup....
1 - 20 of 119 Posts
