1 - 13 of 13 Posts
i know its crap now but until i manage to get a new vc, i wanted to get some tips on how to oc this particular card, and if anyone has any useful suggestions i would greatly appreciate it. thnx
Hey welcome!<br>
You can download ATiTool .25 beta 14 <a href="http://www.techpowerup.com/downloads/259" target="_blank">here</a>.<br>
Info about ATiTool:<br><a href="http://www.techpowerup.com/atitool/" target="_blank">http://www.techpowerup.com/atitool/</a><br><br>
Once installed "Find Max Core" and "Find Max Mem" and run them each for about 15-30mins to get an idea of your stable core and mem frequencies.
Another tool that you can use to OC is called <a href="http://www.guru3d.com/atitraytools/" target="_blank">ATI Tray Tool</a><br><br>
Supposedly, it gives you an extra 15-20 mhz of stable OC. I'm not sure wether or not this is true.
<div>Originally Posted by <strong>PureSolo89</strong></div>
<div style="font-style:italic;">Another tool that you can use to OC is called <a href="http://www.guru3d.com/atitraytools/" target="_blank">ATI Tray Tool</a><br><br>
Supposedly, it gives you an extra 15-20 mhz of stable OC. I'm not sure wether or not this is true.</div>
</td>
</tr></table></div>
ah, u beat me to it
ATi Tray Tools has ripped someone off. I don't remember which, but someone it did.
Discussion Starter #6
thanx for the help and the welcome all. i downloaded all the programs suggested i i just gotta test them and see what i can do with them and i started to run find max cor but after about 3 mins, my machine locked up.find max mem only ran for about 6 mins and same thing. also another question i have is about cooling the card. i have the fan that was already on the card but i was wondering if that was enough or would i need extra cooling once i get a stable oc
Its ok to oc with the stock cooling but you could definetly get a higher oc with after market cooling, you can get a cheap vf700 and it'll help alot<br />
<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835118117" target="_blank">http://www.newegg.com/Product/Produc...82E16835118117</a>
<tr>
<div>
Originally Posted by <strong>Protius</strong>
</div>
<div style="font-style:italic">Its ok to oc with the stock cooling but you could definetly get a higher oc with after market cooling, you can get a cheap vf700 and it'll help alot<br />
<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835118117" target="_blank">http://www.newegg.com/Product/Produc...82E16835118117</a></div>
</td>
</tr>
</table>
</div>For that 30$, he could get a 9200. <br />
<br />
Dont spend anything unless it is a new card.
Discussion Starter #9
i thenk u guys for your help i think i'll just stick with stock till i can upgrade
Definately upgrade the card not the cooler.
yeah, most definatley upgrade the card.<br>
Whats your Budget?
Discussion Starter #13
i can spend about $50-$100, any recommendations in this price range?
1 - 13 of 13 Posts
