1 - 6 of 6 Posts
Well after spending days and days trying to cram a whole bunch of stuff into my old koolance tower, I finally said F-it and upgraded to a HAF 932. Couldn't be happier.
Before:
After:
Well this case is huuuuge! Plenty of room. I have my 360 radiator mounted up top, with 3 120mm fans sucking air from the top and pushing it through the radiator. The case also has like a 160mm fan in the back, and two monster sized fans I can't even guess their size. Surprisingly this set-up is a lot quieter than my old set-up.
Also bought a touch screen fan controller which is pretty cool, I still need to figure out how to work everything on it, but you can control up to 5 fans individually which will be nice for the 3 on the radiator.
Specs for the watercooling:
Thermaltake p500 pump
swifttec 360mm radiator
Zalmon Gold CPU block
two 8800 GTS cards that came with BFG watercool blocks
Double bay reservoir
Loop:
Pump>radiator>cpu>gpu>gpu>reservoir>pump
Anywho thanks for looking, I'm very excited with how it turned out
Just need to make a stand for my pump to replace the foam I have it sitting on and I'll be all set.
You need a new CD drive
Anyway, nice job but I would try some cable management. The HAF932 has many opportunities to hide some wires
If you got some time on your hand you should manage those cables. Messy wires makes your system look less appealing.
Discussion Starter #4
Yeah, I don't know how you guys do it, my wires aren't long enough to go through the backside. My system would look 100x better without these stupid cables.
1 - 6 of 6 Posts
