1 - 20 of 27 Posts
Well I made some spare cash and I want to put it into my photo gear for a change!
I currently have
Canon t1i
Canon 28-135 USM IS lens
Canon 50MM 1.8 prime lens
Canon 18-55 IS Kit Lens.
Here is scenario 1:
Sell 28-135 lens for $280 ish, buy Canon 15-85 lens for $640 refurbished. Keep t1i. Cost to me $360
Here is scenario 2:
Sell t1i for $500ish, buy 60D for $890 and keep current lenses. Cost to me $390
What would you do in my situation with my current gear and why?
You're not gonna be able to sell the T1i for 500. Buy a T2i. Yeah its pretty sidegrade-y, but its a big improvement. And then also do scenario 1 and sell the 18-55 too.
I am seeing t1i's sell on ebay for $500. Why won't I get that out of it?
d[ o_0 ]b
what do you normally shoot. and why do you feel you need to upgrade what you have?
i would sell the 18-55 and the 28-135 and buy a 17-50/2.8.
Originally Posted by capitaltpt;15348726
Invest in lenses, not camera bodies. Bodies lose their value rapidly.
Why would you sell the 28-135 to buy a 15-85 and keep your 18-55?
Keep either the 18-55 or the 28-135 and invest in something on the telephoto end...like a 70-300
This.
Too much overlap with the 18-55mm and 28-135mm. Keeping those two or any one of them with the 15-85mm is just redundant.
Also, keep in mind that when you sell off things on Ebay, they're going to take a huge cut out of your profit. Realistically, I'd look at $400-$450 for a T1i body, $90 for an 18-55mm, and $230 for a 28-135mm.
I'd also consider selling on a forum like POTN instead simply because the buyers there aren't idiots. I've recently sold an FD 50mm f/1.4 on Amazon and the buyer twice tried to get a refund because:
a. Product was "defective" because it wouldn't mount on her 50D
b. Product was "not as advertised" because she assumed it was new even though it clearly was listed as "Used - Good" and she'd have to click on "Used" to even see my listing.
x2.
So yea, sell on forums. You'd make the same amount of money more or less anyways (after Ebay/PP fees) and the buyer base is usually more knowledgeable and will give you less headaches, not to mention there's usually less buyer scammers on forums versus Ebay.
And I'd also second the "invest in glass" statement. With regards to bodies, what exactly is your T1i failing at/what does the 60D offer that you need that makes you want to upgrade?
If there really isn't a need there yet, I'd rather just sell off the lenses and go for something else. Personally I'd keep the 28-135mm, sell off the 50mm and 18-55mm for ~$200 total, and spend an extra $200 out of pocket for a used Sigma 30mm f/1.4 or sell off the 28-135mm and 18-55 for ~$330 then spend an extra ~$200 out of pocket for a 70-200 f/4L, and an extra ~$250 out of pocket for a Tamron 17-50 f/2.8 non-VC depending on your needs.
I want to upgrade lenses because the images I get out of my 50MM 1.8 prime lens far surpass the ones I get out of either of my other two lenses. It seems like they are pretty inferior to the better ones like the 15-85, or the L 24-105.
Discussion Starter · #13 ·
Originally Posted by jsigone
first off...what do you shoot?
Well most common are Cars, People, Animals, and landscapes. In that order.
Discussion Starter · #16 ·
Originally Posted by sub50hz;15355902
Don't buy that Tamron.
I wouldn't buy anything but Canon so don't worry!
Canon's 10-22 is excellent, but the Sigma 10-20 4-5.6 is nearly every bit as good for a whole lot less.
Discussion Starter · #18 ·
Thats not quite what I want. I am looking for something with around 70 for a little bit of distance.
didn't really recommend THAT lens, just something simular focal range, but canon version is twice the cost LOL and was stated in my post. The tokina 11-16/f2.8 is a SWEET lens but 700ish and don't see too many pop up on the used market. Their 12-24/F4 is nice as well though I haven't played with that one, just the 11-16.
1 - 20 of 27 Posts
