My case design
735 17
ok so i decided to make a case design in "LightWave"
Here it is, not finished yet.
Tell me what you guys think, like what would you change, what do/dont you like etc..
Thanks
1 - 18 of 18 Posts
I like computers
Pretty cool.
Hi.
I really like front-side as it looks great for air-circulation.
Are you going to have side-fans, or fans on the top?
It also looks like you have side-mounted external drive bays.
Is there a functional purpose to the wider-bottom?
Do you like the angularity of the facets and transitions between planes? If not, would it be possible to soften them?
Nice.
Are the optical drives mounted on the side? That's actually pretty functional.
Thanks
Nice Sci-Fi/Industrial look.
Might want to have the backside flat (or removable), so you can get into the case horizontally (like adding a new motherboard).
Also nice to see someone use a different 3D program, too.
Discussion Starter · #6 ·
Originally Posted by Syrillian
Hi.
Well the inside will be laid out like the Silverston Raven, so i may add 2 top fans exhausting GPU and case heat. Also i may add side fans, it all depends if i can keep the design the same
And nope there is no functional purpose for the wide bottem, its just for looks.
And yeah i can soften up the edges
i will give it ago.
Originally Posted by Shift.
Nice.
Yep they sure are
Sweet!
And, what materials/mediums will you be using?
Well i would probably use alluminum. But sadly i dont think i will ever be making this case
i dont have the tools or the skills to do it lol. Still fun to design though
You can do that design with a standard case, and use resin (even hard foam) for the exterior.
That case is bad ass I think, take your time save some money and try making it, even if you have to build around some junker case.
Also you should have bottom fans instead of side fans since you plan to make it like the raven.
I like computers
After admiring your design for awhile, there is only one change I could make. Angle the top edges like the bottom. Not sure of you get what I mean.
Make the HDD trays removable like the Cosmos
I would think that it is mainly the lack of tools. Properly equipped, any desire that is in the realm of reality is possible.
Still, you clearly have a talent. Perhaps you could keep fine-tuning and creating, and offer them up as ideas for those that do have the pre-requisites to take on such an endeavor.
Discussion Starter · #18 ·
I do. I will probably do that, at the moment it looks very square
thanks
Originally Posted by TestECull
I like it...it means business, like "ZOMG OM NOM NOM HERE'S FRAMEZ".
Have you made any renders of the internals? If not, make sure the HDD bays don't interfere with airflow and GPU's...
Nope haven't designed the inside yet. and thanks for the suggestion
Well i dont mind anyone using this design, would be awesome to see someone do it. As long as they dont make any money out of it
1 - 18 of 18 Posts
