My Case is full of finger prints.
1052 28
what can i use to clean finger prints off my case? i used a cloth but it made lots of scratches that are visible only in the light. i would take a picture to show you but the prints do not show up on the photo. Thanks for the help.
1 - 20 of 29 Posts
Programmer
thanks for the help. i will look into all these suggestions to decide what will be the best for me. Thankyou.
alcohol on a clean
cloth will clean and remove any grease from your case.
Programmer
Discussion Starter · #8 ·
I will look into all of these idea's, thank you.
Originally Posted by Zoki318
Just use some sandpaper. It will get rid of the finger prints.
lolz, gotta watch out, some people might actually try that
but yea i'de go with the microfiber
I use glass cleaner like windex (although its some general brand) for the window, also seems to do the job on the rest of the case. Microfiber cloth of course if you have one.
I heard a ShamWOW is pretty incredible.
hye, sorry for hijack, but it seems the OQ has been answered.
how do i clean dust off acrylic? it is just so statiky (not a word
) that as soon as I wipe it clean, more dust sticks to it! you can literally see it being attracted to the plastic!
its transparent acrylic BTW.
Hi
There is a specific product called Brillianize. It is an anti-static plastic cleaner.
There is an acrylic guide that is stickied in the rap nodding section.
Oops... lemme edit this on a real pooter, not my phone.
Here is a link to the thread in the general modding section.
i should think paper towel + rubbing alcohol would do fine
1 - 20 of 29 Posts
