erm, no i dont use AS5, i used the thermal compound that came with it and my case is siting on my desk so its not trapped away somewhere, its not dusty as i can see into it now, im just asking if there temp are correct?
I mean its only a 500Mhz overclock lol and its at its max recommended temp to go for athlon 64's AGH!
You should really get some AS5 and do a reseat with the BT, you should be getting much better temps than that. Although, it could just be your ambient temp. is really high...
I just turned my case fans on (one side and one above, suck and exhaust, and they dont even push much air, more for looks) and after about 5 mins it has gone from 40 deg C idle to 33 deg C idle
-7 drop with like crappy fans that dont push much.....hmmmmmmmmm, you think i should take the fans off and just leave holes in the case? would be better prob
Overclock.net
