1 - 4 of 4 Posts
Well, let me start by first saying I am no audiophile. I have recently been on a get the most out of my PC phase and now i'm on to audio. I use my on board sound and play my audio with Winamp, Rock preset EQ. I have a 3 speaker (2 regular speakers, one big one with a bass hole or whatever its called.) Altec Lansing I bought from Costco a few years ago. I recently missed the $30 sound card that was a big deal on Amazon.com, but I wouldn't know how to tell if it would make things sound better anyway. I have an iPod but would like to replace it with a Zune within the next few months and am probably going to buy those Beta Brainwavez for it. I bought a pair of Koss KSC75 on Amazon a month ago for $15 and just now opened them. I usually prefer to play games and music through my speakers but may start wearing these for games for added immersion.
Consider upgrading is you want that "1080p" of audio, else, onboards these days are perfectly fine to listen to music, movies and games, 99% of the time..
The thing with the hole is a subwoofer
I used winamp for +10years
The thing that could harm the sound is probably the way you set up your speakers. I think those are cheap ones, but it can still play great at a given volume with a decent EQing.
You probably have a bass level on that sub(woofer), don't set it to 10 (Let's say it's 1 to 10). I'd set it to about 3-4..
To get to the sweet spots with the speakers tones (if you have a knob for that), I would probably set WinAmp to the Classical preset.
I'd compare with the Rock preset and stuff, but probably would stick to the classical one and then fine-tune the tone knobs and sub bass.
Classical presets usually EQ around the mid/hi ranges than bass, but not too much, I think that it's better than a flat EQing..
Sure some would say ohhh you need to get the real sound before EQ the hardware (flat software EQ and then fine-tune the speakers knobs), but I don't agree.
Find the average volume that you'd use before making permanent settings, because lowering-raising the volume will change all the dynamics.
1 - 4 of 4 Posts
