After a lot of monneeeyyy and sweat and stress and leaking and assembling disembling it finally finished, and I present you my piece of art, the Disco PC(Disco ball will be added asap)
PC SPECS:
ASUS RAMPAGE FORMULA MB
Q6600 LAPPED 4 GHz
2X WD 500GB RAID 0 HDD
ATI HD4850 512MB VIDEO CARD OC
Creative X-Fi Extreme Music Sound Card
STACKER FULL ATX ALUMINIUM CASE
COOLING SYSTEM BELOW
Materials
CPU BLOCK-----------Swiftech Apogee™ GTZ Universal CPU Waterblock
GPU BLOCK----------- EK Radeon HD4850 VGA Liquid Cooling Block
RADIATOR-------------Danger Den Black Ice GT Stealth 240 X-Flow Radiator - Red
RADIATOR-------------MAGICOOL PRO II 240mm RADIATOR
RESERVOIR----------- MAGICOOL Magicool 250ML CYLINDER PLEXI RES
PUMP-------------------Swiftech MCP655-B™ 12v Water Pump w/ 3/8" Conversion Kit (1200 L/H)
FAN 120mm-----------NOCTUA NF-P12 1300RPM 120mm SILENT CASE FAN
FAN 80mm-------------NOCTUA NNF-R8 SESSİZ 80MM SILENT CASE FAN
HOSES------------------4 M 1/2 HOSE
MODS----------- Logisys Dual 12" Cold Cathode Kit - Blue
PASTE----------- Shin-Etsu X-23-7762 Silicone Thermal Compound - 1g
COOLANT----------- THERMALTAKE COOLANT 1000CC ULTRA VIOLET
I GET FULL LOAD AT 4 GHZ MAX 65 DEGREES OF CORE TEMPS, 2 RADS DONT MAKE MUCH DIFFRENCE DURING IDLE BUT THEY KICK IN ON LOAD.
TONIGH BIG HEAT AND PERFORMACE TEST TO BE PERFORMED AND TO BE PUBLISHED FOR THOSE WHO ARE INTERESTED.
RSPCT
btw: damn how hard it is to keep the case tidy eh?
AND BELOW ARE THE PHOTOS
