1 - 20 of 29 Posts
Operation Goldfinger Shall Commence In:
CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), quality = 85
This build log would not have been possible without the awesome effort of Hanoverfist and his great paint skills! This build has changed shapes and names quite a few times in my mind leading up to this. After looking at the first few panels Hanover had painted I finally choose Goldfinger. I'm a huge Bond fan and this is my favorite of all the films in the series.
Case and accessories
Caselabs S5
360 drop in mount
window and vented top and sides
240 flexbay radiator front mount
Paint job by Hanover
Components
MSI Micro ATX DDR3 2600 LGA 1150 Z97M Gaming
Intel i7 4790
Corsair Vengeance PRO 16GB DDR3 2400
EVGA GeForce 980 GTX ACX
Inted 730 SSD 240
WD Black Series 1 TB
Swiftech Helix 120mm Z-bearing Fan (will Paint) Switched to Noiseblocker E-Loops
Swiftech MCP35X 12 Volt VDC Pump
EK-DDC-Xtop Plexi
EK-DDC Heatsink Housing (will paint) Also changed to a Bitspower True Brass housing
Darkside low profile 240 and 360 Radiators
EK Geforce GXT 980 Liquid Cooling Block Nickel
EK Supremacy EVO CPU Block
Phobya Inline Temp Sensors
Aquaero 6XT (harvested from TH10 build)
Aquacomputer Flow Sensor
EK HD Tube 10/12mm
Bitspower Fittings (right now blacksparkle but possible change) Changed to True Brass
EK GTX 980 Backplate (will be painted)
Mayhems X1 Clear and will use some blue dye
Sleeving
Ensourced will handle primary PSU sleeving
Fan and Pump sleeving will be decided soon
Discussion Starter #4
I will be painting some small internal parts as well the awesome Darkside rads, Gpu backplate, and Fan blades. Here are some test pics I took with my new camera setup. I"m also planning on getting rid of all red accents on the motherboard.
polished the pump top and res ends as well
Discussion Starter #8
Originally Posted by guitarhero23 View Post
Cool gold
Thanks
Originally Posted by Pheozero View Post
That paint job tho
All of my subs
Thanks this log will be pretty quick. I'm already working on the loop, bending acrylic for the first time.
Discussion Starter #14
Here are my final pics the build is done. I tried to get some outdoor photos with the sunlight but no luck. I also got rid of all the red accents on the MSI Motherboard as well.
Discussion Starter #16
Originally Posted by duckweedpb7 View Post
Turned out awesome, very tidy and the colors are great! Good call on getting rid of the red accents too.
Thanks duckweed! I can't wait to see how your TH10A comes out!
Originally Posted by Newtocooling View Post
I have completed the loop and decided to try some low light pics and a few test shots with Dazmode's Awesome Darkside LED's.
Testing low light
Ensourced Cables should be here tomorrow.
Can you please elaborate on what color LEDs you were testing? Are the first two pics BLUE LED and the second two UV LED?
It looks that way and may be obvious but I can't be sure my monitor is showing what you intended.
And, I assume your cooling liquid is clear with blue dye (non-UV), correct?
Looks great in any case. Well done.
Discussion Starter #20
Originally Posted by 1911Savage View Post
[/SPOILER]
Thanks for the kind words. Yes you"re right I'm using Darkside RGB LED's here is a pic of the setup, and a link where you can find them. Dazmode is Canadian Store and he's got his own brand of watercooling components now. He has LED"s, Rad, and all kinds of sleeved cables as well under the branding Darkside. He's a great guy and really passionate about all things water cooling
https://www.dazmode.com/store/category/best-rbg-led/
1 - 20 of 29 Posts
