1 - 7 of 7 Posts
Alright, so I used DVD Shrink to backup a DVD I had, then burned it. It was originally 2-layered, but it used a 57% compression rate and it came out near perfect. The only gripe is that on the main menu, the "cursor" to select scenes, extras, setup or play, isn't there. Normally it lights up the part you're highlighting green. If I hit enter and move around, I can still select different menu options, I just don't know where I am.
That's only on the main menu, though. The submenus all worked fine. Why could this be? Just an error while being compressed, or is it something else? Should I try again, or will I likely get the same effect?
Try burning at a slower speed.
The BIG question is what does this have to do with AMD?
I may be moving this to the "Other Software" section!
Discussion Starter #7
Ah, sorry Duke. I looked for something like a 'DVDs and Backups' section, but there was none. It's a pain when you get much slower responses elsewhere. On the AMD board, there's always tons of people.
1 - 7 of 7 Posts
