1 - 15 of 15 Posts
Hello everyone, I'm upgrading from an old dual core build by Dell.
I've got an average computer knowledge but I need to be sure if I am doing the right thing here, so please be patient.
So here is the setup I am planning to buy from Newegg.ca
Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I72600K
ASUS P8P67 PRO LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813131682
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-8GBXH
XFX HD-687A-ZNBC Radeon HD 6870 Black Edition 1GB 256-bit DDR5 PCI Express 2.1 x16 HDCP Ready Video Card with Eyefinity
Recertified: Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
COOLER MASTER RC-692-KKN2 CM690 II Advanced Black Steel ATX Mid Tower Computer Case
Noctua NH-D14 120mm & 140mm SSO CPU Cooler
Item #: N82E16835608018
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power ...
??? My questions ???
Is that an overall good build ?
I find the RAM a bit overpriced, I don't understand is the timing and such, so I don't know if it's good, anything about that ?
If I want to overclock it, will that fan carry it without problems? The power supply is fine too ? I've also heard that the 2600K OC isn't that hard, is there any risk if it's my first OC ?
My MB will fit the case ?
You got any suggestions about the overall system ?
Thanks to you for reading me, hope you can help.
-TheSpartan
Alright, thank you very much for your reply, still about the RAM, now that I understand the timing, what about the frequency ? You've linked me to lower frequency RAM, I've chosen 1600, is that too high or something ?
Thanks again
-Spartan
-TheSpartan
The RAM is great - good speeds and tight timings. Should do you very well.
Overclocking the 2600k will be easy, but that cooler is probably larger than you need. These chips have been overclocking to 4.4ghz+ on stock coolers- you should definitely get a cooler, but you can save some money there.
Also the 6870 has a low headroom for overclocking, and is thus overpriced compared with its smaller sibling, the 6850. A large overclock on the 6850 will put its performance above a stock 6870. My Gigabyte 6850 ($179) runs very cool and quietly, and performs above what a stock 6870 does.
(Proof: http://www.tweaktown.com/reviews/3646/gigabyte_radeon_hd_6850_1gb_video_card_overclocked/index.html)
The money saved between the two (avg. $40-$70) and with a smaller cooler ($30) could put you 2/3rd's of the way towards a 6850 crossfire setup which is the best bang for the buck now, or up to a 6950 almost all of which can unlock to 6970's.
Why a refurbished HDD? Have you had any luck with refurbished drives before? I've never entertained the idea of using 2nd hand HDD's.
Everything else is perfect, and whilst I'm not a huge fan of that case it has a great feature set and loads of support from many users.
Reactions: Triangle
Discussion Starter · #6 ·
Alright, I've decided to go with a XTF Radeon 6950, I've chosen another RAM pack wich seem to be the exact same thing for a lower price :
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231401
Just the design seem a bit ugly compared to the other, but idc.
As for the fan, I would want to follow your idea on the smaller fan, do you have any lower priced fan to suggest, but I want it to still do the job
EDIT : And for the case, I ended up with this one, because i was tired of looking at cases, if you got any cases with front panel usb 3.0, just write it down
Thanks again
Will probably go with the H50, thanks
Are you trying to push the price down, trying to save space in your case or both?
The H50 is more than enough for Sandybridge overclocks too.
You could easily get away with something like this:
http://www.newegg.com/Product/Produc...82E16835181012
or these:
http://www.newegg.com/Product/Produc...82E16835233040
http://www.newegg.com/Product/Produc...82E16835233059
http://www.newegg.com/Product/Produc...82E16835106139
And any would be more than enough to keep any sandybridgeK processor cool and happy running up to 5ghz. Frankly ANY cpu cooler that even looks like it's more elaborate than the tiny stock coolers that come with many processors (the little circular ones with a like 30mm fan) will likely do an acceptable job.
From everything I've read, you could slap this on and be fine:
http://www.newegg.com/Product/Produc...82E16835103074
It's very small, and might be louder due to the fan size, but it will work. By no means am I recommending this, as you should really go fore something $10 more and much larger and quieter, but for establishing context, you don't need to spend much or mount huge coolers for your overclock.
Anyways - you have many options with Sandy processors, as they appear to hit an overclock wall well before temps become an issue.
Read up here:
http://forums.anandtech.com/showthread.php?t=2133854
Good luck
Discussion Starter · #15 ·
Originally Posted by triangle;11991141
Good luck on this build.
Thanks
I've got everything already shipped and will receive my first package out of four tomorrow.
I would also like to know if it's possible to change the front panel USB 2.0 of my case to USB 3.0 port since my motherboard support USB 3.0.
Thanks
1 - 15 of 15 Posts
