My first true OC
243 Views 1 Reply 2 Participants Last post by  billbartuska
Sooo I started OCing a lot today after messing around a lot yesterday only with the mutiplier and here is what i came up with.
I wanted to know what you all think my main concern is the Memory Frequency... I would like to up my FSB a little more but I have been worrying about the memory? Will the memory be able to handle higher frequency how high should I be able to go without really having to worry?
Thanks for any insight already addicted to OCing and I just started the past 2 days
1 - 2 of 2 Posts
The Cliff's Notes of overclocking:
Unlink the memory and the CPU.
Find the max FSB you motherboard will run.
Find the max you CPU will run
Find the max your memory will run
Then put them all together into an overclock.
As long as you're not changing voltages, nothing will break.
Two days???? It'll take 6 mo - 1 Yr to get good at it. Read a lot!
1 - 2 of 2 Posts
