After I installed my wb I started to run into freezing issues. My card wont run Vantage or Heaven it freezes in the middle of the bench.
I increased the voltage it ran once fine, tried one more time with same settings and it froze again. I OC'ed mildly with higher v and core (1.075/860)
it didnt work either. I really dont want to remove the card to put back the stock cooler because of the loop...I dont know waht to do.
I revert CPU back to stock, it didnt make any difference
Is my card dead?
Edit: 04-06-10
I just installed my new CPU, mobo, case and reinstalled the GPU wb. Installed a fresh windows and still getting the same problem
PSU wudnt cause this issue right?
RMA time for GPU?
Is my card dead?
Edit: 04-06-10
RMA time for GPU?
