My gpu only loop = Thoughts/Suggestions?
415 10
Hey guys, I'm thinking about throwing my 580 back on water along with another 580 in the future. Here is my part list:
2 x EK 580GTX+
XSPC RS360
Swiftech MCP350
XSPC Liang DDC Reservoir
3 x High Speed Yate Loons in a pull configuration
Now, what I'm wondering is will this keep my 580's under or around 60-65c on full load with a hefty overclock? My ambient temps during the summer are usually around 30c.
1 - 11 of 11 Posts
Get a RX 360 At least, the RS360 won't be enough and personnally I would go Push/pull configurations so 6 fans
AMD Overclocker
I might just try it out first instead of investing in a new rad just yet. If i'm unhappy with the performance, i'll just get an rx 360 like you said. Thanks for the input!
You're welcome, anytime
AMD Overclocker
Discussion Starter · #6 ·
Originally Posted by RushMore1205
even with the RS kit you will be way under 60, my 470 with 800mhz when stock at 607 never break 47c
When I had my cpu + gpu loop, it went pump/res>gpu>rs360>cpu>rs240>pump/res and I was getting load temps in the 50's for my 580. So, I doubt that using sli with a loop like that will prove very effecient. That's why I'm splitting them up, gpu's can take a higher air/water delta than cpu's can. As long as my gpu's don't go over 70c, i'll be happy.
They both have excellent, the RX360 is thicker with wider fin spacing so it does better with low-speed fans. If size is an issue the RS360 will do just fine.
AMD Overclocker
Discussion Starter · #8 ·
Space is a bit of an issue, since I will have the 360 hanging off the back of my case, so the thicker the rad, the more it sticks out from the wall.
AMD Overclocker
Originally Posted by Somenamehere;14114965
Drop the EK blocks quality, and customer service is horrible.
I actually already have one ek block and the rs360 rad. And i've never had any problems with ek personally, so until then I'll keep using their products. Btw, i'm using a copper block, not nickel.
1 - 11 of 11 Posts
