My GTX 275 1792MB
377 Views 8 Replies 8 Participants Last post by  Anth0789
Ok so how awesome is it?
I really don't get what makes the 1792 version so much better than its 896mb counterpart? More memory = better fps?
Also, I haven't pushed it past stock limits yet. I seem to be able to play any game I have thrown at it (COD: MW2, CS:S, Oblivion, Fallout3) at max settings with no problems. Should I OC it or is there no point and it would just be for benchmarks?
Just looking for some info about my card I feel so in the dark
1 - 9 of 9 Posts
It'll perform a bit better at extremely high resolutions but at sane people resolutions you wont really notice a difference.
The game I play most, CS:S, I run at 1900x1200. Is that not a sane people resolution
Only thing the extra memory is really good for is when you SLI the cards. (Since the memory doesn't stack)
Other than increased resolution and AA.
i would definately try oc'ing it and see what it is really capable of handling. the evga precision tool is very easy to use.
Moar pixels. Larger res, & ability to handle larger texmap sizes.
Review on that:
http://www.techpowerup.com/reviews/M...htning/30.html
There is a little jump when you compare it to the regular GTX 275.
1 - 9 of 9 Posts
