Case: NZXT Phantom (Black)
http://www.newegg.com/Product/Produc...82E16811146068
GPU: MSI Lightning GTX 580
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127579
PSU: XFX Core PRO850W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207011
RAM: Corsair Vengeance 2x4GB
http://www.newegg.com/Product/Produc...82E16820145345
Mobo: GIGABYTE Z68
http://www.newegg.com/Product/Produc...82E16813128502
CPU: Intel i5-2500K
CPU Cooler: Corsair A70
http://www.newegg.com/Product/Produc...82E16835181011
HDD: Samsung Spinpoint F3
http://www.newegg.com/Product/Produc...82E16822152185
What do you think of it? Anything I should upgrade/downgrade?
Max budget is $1300.
Also, about the GTX 580, should I keep it or change to a 570? I'm running at 1920x1080, so...
Mobo: GIGABYTE Z68
CPU: Intel i5-2500K
