1 - 8 of 8 Posts
Overclocking
I though I would post up about my Cheap TCCC samsung 512x2 PC3200 memory<br><br><a href="http://imageshack.us" target="_blank"><img alt="" src="http://img241.imageshack.us/img241/6736/untitledjz0.jpg" style="border:0px solid;"></a><br><br>
My motherboard has the PCI/AGP limit so I can only go so far. IM runing all stock. CPU = 1.450V (0.13um core), TCCC PC3200 = 2.5V. I have ok cooling for the cpu but no cooling for the ram and its been stable so far. So is this fast memory for a lower end system... Rember look at sig
Overclocking
<tr>
<div>
Originally Posted by <strong>ENTERPRISE1701</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1399312#post1399312" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Whats your overclock at for your CPU ?</div>
</td>
</tr>
</table>
</div>1889mhz. 210FSB @ Stock voltage and some copper cooling. Read my sig for my overclock and specs because my motherboard sucks for overclocking
For about $70 you could get a ASRock Dual Vista <br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813157097" target="_blank">http://www.newegg.com/Product/Produc...82E16813157097</a><br />
and for $65-80 either a 3000+ or 3200+ venice or a 144 Opty.<br />
Everything else you have is transferable.<br />
The Dual Vista MB supports AGP and PCIe16 and has very good BIOS options and OCs rather well too! <br />
BTW, just because the TCCD don't have a heat spreader don't mean it can scream, Samsung made some very good chips. I'd venture to say you should get 210 @ CAS2 speeds with more voltage... it don't need a lot, 2.8-2.9 max.
Overclocking
Discussion Starter #5
<tr>
<div>
Originally Posted by <strong>The Duke</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1399824#post1399824" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">For about $70 you could get a ASRock Dual Vista <br />
BTW, just because the TCCD don't have a heat spreader don't mean it can scream, Samsung made some very good chips. I'd venture to say you should get 210 @ CAS2 speeds with more voltage... it don't need a lot, 2.8-2.9 max.</div>
</td>
</tr>
</table>
</div>I know that stuff. If you can send me A Nforce3 Chipset for SOCKET 754 than I'll show you A overclock. The 64 2800+ with good cooling got around 2.5GHZ before. All I need is a motherboard and A better heatsink like copper<br />
<br />
<b>BTW, its not TCCD memory its TCCC value ram memory!!!!!!</b>
You need a MB? <br />
I have a Biostar TForce 6100 754.<br />
Check some reviews, it should OC well.<br />
<a href="http://www.ocia.net/reviews/biostarforce/page1.shtml" target="_blank">http://www.ocia.net/reviews/biostarforce/page1.shtml</a>
Overclocking
Discussion Starter #7
<tr>
<div>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1399876#post1399876" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">You need a MB? <br />
I have a Biostar 6100 754.<br />
Check some reviews, it should OC well.</div>
</td>
</tr>
</table>
</div>I don't know though. How much would you want it for because than I can save up, because my family is broke and im broke like always so it might take a few days depending on what you want for it<br />
<br />
BTW. Holy crap, 1.8V CPU voltage, 2.9V memory voltage, 450FSB (Like I'll hit that) wow! HOW MUCH!
Sorry,darn phone ...<br />
YGPM<br />
<br />
Ummm. 300 is about the ceiling on the FSB from what I recall, the 450 is probably what the setting may reach but 300 actuall is more like reality.
1 - 8 of 8 Posts
