My Mother board speaker is SCREAMING!
1890 Views 17 Replies 9 Participants Last post by  DeathMachine
Hi please can someone try explain to me what is going on with my PC. Whenever I am running a lot of programs/processes at once, my MB speaker Screams at me, one continuous beeeeeeeeeeeeeeeeeeeeeeeeep. It started when I was playing Mod warfare 2. I thought the GPU was getting too hot so I took off my side cover. It did stop it from screaming until now. When I open Google earth and try zoom into a city, It stars again. i took a screen shot of my task mannager if it helps. This screaming sound is driving me crazy, does anyone know why???
1 - 18 of 18 Posts
Are you sure its not overheating?
tried looking at your temps? speedfan or realtemp should give you an idea...
you're screenshot doesn't tell me much at all... what is your 920 running at?
what are your temp alarms set to in your bios?
Sounds like capacitor whine. Happened to my graphics card and now it has a critical core power failure
Is it a high pitched whine or an actual beep like a beep you get when you turn your PC on?
I will post a pic of realtemp stats when I run Google earth and it starts screaming
It is the motherboard speaker, the one shot beep, one long beep kind on the board, not a capacitor whine, not that high pitched
Check the beep code list.
I dont get a specific code though it is just constant.
I had the same issue once and it was my fan fail warning, my CPU fan was spinning too low causing the alarm to go off. It was also a Gigabyte board. So check the fan speed and see if all is running ok. My prob was caused by SmartFan.
Cool I will check it out
If you deem everything to be in working order, either unplug the speaker or disable it via the BIOS.
I didn't realise motherboards shipped with speakers anymore
My last 3 boards never had one.
Ok I think I have found the problem. My warning temp. was set to 60 Degrees C. I was hitting 62 in Google earth. I have changed my warning temp. to 70'C. What is a dangerouse heat to hit on the i7 920?
as a loose rule of thumb, most people stay below the Intel published "Thermal Spec".
Pick your stepping 920 here
spoiler:
it's 67.9C for both lol
spoiler:
Ah ok So I am doing just fine then! Thanks a lot. I'll just leave my danger temp on 70 and so far I have had no beeping sound.
pull it off
Originally Posted by manolith
pull it off
Wow that plan is genius if I understand it correctly ...
ha haaaa!
1 - 18 of 18 Posts
