Short question: How do I use molex fans if my PC doesn't support molex?
I purchased some cooling products, but they are molex connectors. I don't know what to do about them, but I assume that I can get some sort of adapter or something. I only have one fan connector to my motherboard as well, so I really don't know what to do.
yeah, plug them into your power supply. They will just run at 100% all the time (unless u have a fan controller) instead of being controlled by the BIOS.
I don't know what others would say about this, they will probably have better experience/knowledge about this...but personally I would not daisy-chain them I believe the motherboard fan sockets can only supply low wattage and 3-4 fans will definately go over the wattage and you will trash your only fan socket.
That's what I believe....but it doesn't make it right !!!
Overclock.net
