My NB is unstable even with volts
371 11
i just needed to add .1v to get to 25xx and for the next step which is 28xx i needed to put .15 to boot but even with .275v it wont run prime for more than 2 mins
stock is 1.1
1 - 12 of 12 Posts
Iconoclast
Originally Posted by exzited;14209986
I think in going to retry this after my water cooling comes in. Do temps affect the NB at all?
Yes.
The cooling on my 555BE is total overkill (lapped TRUE, 120x38mm Panaflo high speed) and that certainly has something to do with it's ability to reach decent NB speeds, given it's an utterly mediocre chip in every other way.
Discussion Starter · #8 ·
Originally Posted by Blameless;14210022
Yes.
alright all just have to wait for my rasa kit to some in. what temps are you getting on that x2
Iconoclast
About 20-25C above room temp at maximum load. 4GHz/1.525v core, 2.83GHz/1.375v NB.
Originally Posted by giganews35
I think I will disable 4 cores and see how the 1090t overclocks on just 2 cores.
Be sure to disable the ones that require most voltage. My two last ones need 0.05v more than the other 4 so I just disabled them
1 - 12 of 12 Posts
