Swiftech Apogee water cooling
-Apogee w block
-mcp655 pump
-mc60-r g80 block for 8800gtx<-getting tomorrow in the mail.
-swiftech 120mm rad w 3/8" fittings
-DD Black ice ext II 240 rad w 1/2" fittings
-1/2"ID tubbing exept on the GPU and swifty rad.<-3/8"id
Air flow.
-1front intake 120mm cooler master.
-1side window " " " " "
-1 pull 120mm behind the swifty rad
-2 masscool 54cfms push on BIX240 rad
-2 85cfms pull that im waitig for.
thanks ira-k
pelt-245watt pelt, powered by Ultra 325watt ps in the 5.25"drive bay. Is undervolted to is more like 150watts pelt.
the rest see my info below
drawing of setup:
the mess
dielectric
lapted e6600
wb and pelt w thermal greese and ceramique
gluing the componets together
the block
back of case, this is after the lacker-comformal dryed
cpu
empty
filled
Right now my temps arent as impresive as i expected:
13C idel/35C full load-stable
this is from 35-50c with water cooling alone
this is with about 30C ambient temp
I think my temps are like that for several reasons:
#1-i didnt apply preassure to pelt. just glued it on. unable to all components 50x50mm
#2-the restriction the 120mm rad makes in water flow
#3-too small a peltier-just 150 undervolted
#4small rad/fans cfms
tomorrow ill see how it does with the 8800gtx/panaflo fans/and overclocked.
Cheers!!!!!
-Apogee w block
-mcp655 pump
Air flow.
drawing of setup:
the mess
dielectric
lapted e6600
the block
cpu
empty
filled
Cheers!!!!!
