My Opty Overclock
768 17
I have reached 2.9 with my venus 12 cooler, my load temps are at 44 tops.
Could I go any higher? I dont think i can on this voltage, but if i were to move it up, would i be safe?
edit: also, how much would a TT Typhoon help my temps?
1 - 18 of 18 Posts
If you get those temps with the VENUS, the BT will freeze your freaking proc....lol....go for that BT and push up that vCore.
1.36v
Something is odd!
Originally Posted by The Duke
1.36v
Something is odd!
That is @ stock speeds. 200x11 @ 2210
Yes... where is the 2.9 shots?
nice work, you finally getting it running
...I would change some of your memory settings, If you want, I will give you my complete settings. I would also decrease your voltage to your CPU at that speed. You should be able to get stable with around 1.5v (cpuz). In your bios, set your VID+VID special to equal =1.55v
try 1.375 + 113% for 2.9ghz.
Use this chart, print it, and you will know what each setting does..
I see in your sig you are "soon2mod" your mobo, what do you plan on doing? If modding to SLI, be careful with the epoxy on the chipset, it was put there intentially by DFI to keep people from modding. I'm not sure what else you can mod on that board?! Besides to SATAII, but that's similar to the SLI mod.
The Ultra-D already has SATAII, it's the regular Lanparty D that doesn't have it.
does it? I dont pay much attention to all the little features, I know I'm using sata150 drives....I honestly didn't think it was SATAII.
Either way, I've heard the difference in performance is tiny, if at all.
There's no difference in performance at all. While the drive is capable of accepting transfers at that rate, the processor/mobo isn't.
1 - 18 of 18 Posts
