1 - 15 of 15 Posts
I shutdown my PC 40min ago and it turns itself on. What could be causing this?
This is my PC specs
CPU: i7 Intel 3770k
Motherboard: Asus P8Z77-V
Memory: 8GB Corsair Vengeance
GPU: Sapphire AMD HD Radeon 7950 3GB OC edtion
700 Corsair PSU
Samsung Blu Ray drive
1TB Wester Digial HDD
256GB Samsung SSD
This is my PC specs
CPU: i7 Intel 3770k
700 Corsair PSU
256GB Samsung SSD
you have kids?...perhaps they press the power...room mate? magic Packet?
Originally Posted by _s3v3n_ View Post
Let me take a wild guess.....
Windows 8 OS?
I don't think I've heard of any issues with Windows 8 randomly starting a machine...
It likely has Wake on USB on by default so resetting the BIOS doesn't do anything thing. Go into the BIOS and manually set it to off or unplug your mouse and Printer.
Wake on LAN typically isn't enabled by default, but you should check that too.
If that doesn't do it there is probably something defective with the mother board
Twitch Streamer
Well, you could have a priest exorcise it or you could call ghost busters.. or try resetting your CMOS. I dunno if that will help or not but it always helped me when I had random problems.
Windows 8 OS?
Same here.. I never heard of such thing. BUT I saw it happened to one of my machines.
Not sure if andypandy uses W8 though.
Am I being dumb, or am I the only one looking at the most obvious thing to check first: A badly wired power switch. That would be one of the first things I'd look at after comfirming OS and Bios settings
EDIT: Turns out it was the settings! I was a little late!
1 - 15 of 15 Posts
