My PC wont boot
498 Views 5 Replies 4 Participants Last post by  CanadaGradeEh
Damn, a couple of hours ago, I was changing some of the BIOS options, nothing important, and when I saved and reboot, the PC went in like a Standby, I shut down, and when I power on the pc again the monitor just got black in like a standby, the PC starts but I cant boot, dont load the windows, not even the screen, nothing, the computer just stay there, I can hear everything the fans, HDD, the processor, everything inside working, but the monitor nothing, and the PC dont want to Boot at all, the PC wasnt OC at the moment, I really dont know what happened, please help guys...
1 - 6 of 6 Posts
· Banned
Mate... there's nothing dangerous about removing a bios battery. Just do it gently so you don't break anything.
I'd do what Ty Auchter said because this will reset your bios and hopefully undo any change you could have inadvertently made.
10-4, you guys were right, my system is working perfectly now, the BIOS just checksum error and loaded the defaults, thanks for everything, remenber in this...we all together, thanks alot Cya.
Yea, that happened to me a lot a little while ago too because of unstable RAM alterations I made (I didn't understand RAM timings too well). Like they said, no harm in taking out the battery. All it does it remove the power that is keeping your custom BIOS settings saved, thus setting them back to default.
1 - 6 of 6 Posts
