1 - 14 of 14 Posts
Yes
My brother's cheap guitar (Squire Fender) died so I'm doing a full Fender Stratocaster build.
The parts:
- Fender Pickguard
- Fender Knobs
- Fender Vintage Noiseless Pick-ups
- Fender Super 5-Way Switch
Pick ups:
Knobs & Switch
On to the build!
Pick-ups mounted
Potentiometer mounted
Switch mounted
Pick-ups soldered
5-Way switch soldered
To-Do List:
Finish Soldering Potentiometers
Install and Solder Output Jack
Install Pickguard Assembly
String Guitar
Looking good. I am thinking about learning how to play the guitar.
I am more of a Les Paul style fan myself.
Subbed for awesome.
Sick dude! Im more of a Gibson sg guy but I still respect a great guitar. im stoked to see the outcome of this!
Yes
Discussion Starter #10
Thanks guys
The guitar will be housed in the old Squire Fender body and neck for now. There's a local shop that makes custom Fender licensed necks and bodies. I'm planning on looking into the neck upgrade with a bridge and tremolo swap as well.
Update time!
Output jack finally came in. One small problem, it didn't come with a 2nd nut so it didn't fit quite right.
Quick trip to the Home Depot for a washer
Installed
Much better!
It's all soldered up! Had to move the 3 ground wires for the pick-ups to the top side of the potentiometer, it was bumping into the body of the guitar when I tried to test fit it.
Here she is. There's a small humming issue, I think it's probably because of a bad solder joint. Gonna try and take care of it tomorrow and hopefully post up some clips of it.
Looks great.
*Internet high five* I know that most people would have just tossed it.
For the slight hum, check the height of all the frets, and try adjusting the pickup heights.
Yes
Discussion Starter #12
Originally Posted by AtomicFrost View Post
Looks great.
Thanks! And thank you for the tip. I'll give it a shot. This is the first time I've tried anything like this (learned how to solder while doing it) so I'm really in the dark about troubleshooting.
Yes
Discussion Starter #13
Update: Played around with the height of the pick-ups and it did help but there was a bit of humming still going on. Read online that it might be caused by the ground wire for the output jack. Re-soldered and it got rid of most of the humming. Gonna poke around a bit some more and maybe swapping out the old tremolo ground wire as well.
Nice work, ditch that Squire neck and Tremelo. A quality Fender neck, tremelo and custom nut will make a world of difference.
As for the humming I know that unless you pick up a specific model that those single coils are pretty noisy.
1 - 14 of 14 Posts
