1 - 8 of 8 Posts
ok i have 2 gigs of Gskill HZ ram<br />
<br />
i have an asus a8n32 deluxe mobo<br />
<br />
i have an x2 3800 @ 2.6ghz<br />
<br />
my FSB is 260 and my Ram is running at 174<img src="/images/smilies/eek.gif" border="0" alt="" title="EEK!" class="inlineimg" /> <br />
<br />
im not very good with ram but i know that on my old epox mobo and the same setup it would run at 260 instead of 174 <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" /> <br />
<br />
<br />
could you guys help me fix it <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> <br />
<br />
<img src="http://img143.imageshack.us/img143/5659/fsbramyt8.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" />
do you have the divider option in auto, if you do you will manually need to change it to whatever you want your ram at
oh man its been a while since i had my asus up and running, ok in bios in the advanced options i think there is a option for your ram that will say like ddr400/333/266 or itll be like cpu/5 cpu/4 or whatever, youll want to chooes that to either ddr400 or if your ram cant handle the oc ddr333 and you can mess with some of the other stuff but i would read up on it first <br />
<br />
check out the ocing guides in the cpu section that go over ram adjustments and stuff
Also, try and find out how to enable your RAM to be running at 1T, and not 2T...Also, does look like your on a divider...
Overclock Failed...
<tr>
<div>
Originally Posted by <strong>born2killU</strong>
</div>
<div style="font-style:italic">ok i have 2 gigs of Gskill HZ ram<br />
<br />
my FSB is 260 and my Ram is running at 174<img src="/images/smilies/eek.gif" border="0" alt="" title="EEK!" class="inlineimg" /></div>
</td>
</tr>
</table>
</div>Here:<br />
<a href="http://www.ocforums.com/showthread.php?t=468038" target="_blank">http://www.ocforums.com/showthread.php?t=468038</a><br />
The ASUS website would also be of great help to you. For example:<br />
<a href="http://vip.asus.com/forum/view.aspx?id=20060307051652145&board_id=1&model=A8N32-SLI+Deluxe&page=1&SLanguage=en-us" target="_blank">http://vip.asus.com/forum/view.aspx?...Language=en-us</a>
I would venture to say that that RAM will run 1:1 @2.8v up to at least 260MHz. Set the RAM to DR400 manually.
1 - 8 of 8 Posts
