1 - 9 of 9 Posts
Ok so ever since I saw this case at Computex 2010 I wanted it and now I have it!
I always thought it would be cool to have a 3x 120mm Rad. mounted on the back and I was able to do all this without any drilling or dremeling.
I also have mainly all blue Antec Tri cool fans as I work at a frys and they have one of the highest CFMs and are reletively quiet. I am also controling them all by Lamptrons Touch fan controller. I am only using 5 of the 6 channels as I spliced fans together to be on the same channel as I have a 30W per channel capacity. Anyways here are the picts
Thanks for looking.
Originally Posted by Onions;13087052
nice im wondering it you can fit the 360 in the botom...
you could but I wanted the heat outside the case. well a 240 at least you only have 360mm so the heads of the rad would not fit.
Originally Posted by Onions;13087158
ok so if i put a 240 on the bottom and a 120 on the top and back it wouldnt feel cramped tho right?
hmm well a fan on the back covers the last PCIe slot so having a Rad there would b crammed but you should b able to no problem 120mm on top an 240 on bottom
1 - 9 of 9 Posts
