If you want to make it look the best, here are some tips:
-Rotate the tubing so the white text is not visible
-Hide the pump
-Show the reservoir
-Hide one length of tubing behind the motherboard tray - basically, go res --> pump --> cpu --> radiator --> behind motherboard tray --> res
-Use as little visible tubing as possible
