1 - 11 of 11 Posts
yep my idle temps on my proc are 28*c and load is 38*c now who wants to dispute my awsomness, o and by the way thats the exact room temp for the idle
just thought id inform everyone lol
Discussion Starter #4
ya as5 and nope have had the zalman since i built the pc, and i just finally got a good case with 120mm fans that i moded and added ducting, my temps used to suck, thanks to ducting there awsome
Nice! Is that at stock settings? Oh and are you using coretemp or TAT to check temps becasue if you arent your idle temps will be around 35c I bet. Lets see some pics of that case tho
Discussion Starter #7
i used pc wizard speedfan and tat tat said 32 and all the others said 29 so i guess that averages to about 30 still 1-2 degrees above ambient on air is just awsome, i get flat ambient on my wc rig in asus pc probe ,so if i did this with air for about half the price im satisfied.
ill have pics eventually i just need to get myself a digital camera
Discussion Starter #9
lol hes hungry
Originally Posted by hron
lol hes hungry
I'm looking to try some air ducting...what materials did you use? Pics man!!!
Here is my setup
Snerp had a great idea going...not sure if he's found his fab work area!! I was thinking of just using foam core board...
Discussion Starter #11
1 - 11 of 11 Posts
