So my sig has it all but just to recap:
Hardware:
CPU: Intel 2500k @ 4.5GHz 1.35v
GPU: AMD 7970 @ 1200MHz 1.225v
Cooling:
CPU Block/Pump (all in one): Swiftech Apogee II
Radiator: Koolance 2x140mm
Fans: 2xSwiftech Helix 140mm @ 1500RPM
Temps after 30 minutes of Prime95 and Furmark:
CPU: ~80C
GPU: ~65C
Now I know this is running 100% on everything which would never happen in real world use and that my temps are still within safety limits but don't these temps seem a little high?
The radiator is getting fresh air directly from the outside so air flow isn't a problem at all either.
Either way, just curious!
Thanks!
Hardware:
Cooling:
CPU: ~80C
GPU: ~65C
Thanks!
