1 - 20 of 30 Posts
Looks OK for DDR3.
looks fine... what speed they running at ?
Originally Posted by IT.Wall View Post
1066 I do believe
yea thats fine... anything in the 1600mhz range usually runs at around 9-9-9-24 stock and with overvolting them you can snag 8-8-8-24 sometimes...
for 1066 ddr those timings are fine... tbh if you even could tighten them up a bit you wouldnt notice any difference. You might see a few % increase in latency on a benchmark...
Which Crucials are you using? If they are 7-7-7-20 recommended timings then that's great @1333 but you can get them lower if your only using 1066. Try 7-6-6-20, if that works try, 6-6-6-20, then 6-5-5-20, then 5-5-5-20, then 5-5-5-18, then 5-5-5-15. Also at 1066 (and these tighter timings) you can decrease your volts too.
Good luck.
What kind of Kingstons do you have?
The lowest CAS I see is 7-7-7 for HyperX Kingstons so that's the best you'll get @1333 if you have HyperX. You'll have to under clock to 1066 to get tighter timings then that. You won't need a voltage increase @1066 with tighter timings.
That's great for the value sticks. I see they're 9-9-9 @1333 so if your running them @1333 7-7-7-21 that's a lot lower then they're designed for. So good luck and keep them there, don't even try to go any lower.
You can have preety overclock running your ram with 1600 or higher speed and a little bit tighter timings
Here -->
http://www.overclock.net/amd-motherb...ml#post8667453
i'm planning to add more ram on my system... i'm now looking for OCZ platinum edition.. 2x2GB at 1333mhz on 7-7-7-20.. it was stock timing.. can i get it lowered..??
http://www.ocztechnology.com/product...e_dual_channel
and
http://www.ocztechnology.com/product...atinum_edition
No stay with the same Kingstons you have and get 2X1GB more or go with 2X2 for 6GB total. Your system seems to like them with timings like that. And they're cheaper. The platinums are bad OCers. Stay away from OCZ.
Unless you want to sell your Kingstons and get 4X2GB of different RAM.
If so I'd go with one of these.
1600MHz
http://www.newegg.com/Product/Produc...2526967&name=6
http://www.newegg.com/Product/Produc...82E16820226103
http://www.newegg.com/Product/Produc...82E16820148334
http://www.newegg.com/Product/Produc...82E16820145264
http://www.newegg.com/Product/Produc...82E16820231259
1333MHz
http://www.newegg.com/Product/Produc...82E16820148340
http://www.newegg.com/Product/Produc...82E16820148327
__________________
I don't think those OCZ will run at 1333mhz on 7-7-7-20. Why do you want to buy those? Cheap or used? I just looked and the price is about the same for the OCZ and Kingston. $105 for 2X2GB.
That would work if the OCZ will run at 1333mhz 7-7-7-20 but you know the cheap Kingstons will so...
they are cheap and i think they are one of performance memory.. and they was included with heat spreader.. so i don't have to think about buying heat spreader anymore.. and their timing was at 7-7-7-20 on stock..
which one should i take..??
anyone have idea..??
1 - 20 of 30 Posts
