Since I do not see many around, I figure I would do one since I'm actually in the process of getting my parts. This would be easier if we had a section for it but oh well, deal with the extra space
. This project should be done in the next coming weeks. I just need to get rid of a few more things and I should have the rest of the cash to get everything else.
I've looked around for about a month or so looking at everything I could possibly need and how I want to set it all up. Initially I thought about doing a standard external setup but after realizing how much more mess it would create I decided on trying to do it internally. Yes this means a new case and that will probably be last on the list and not implemented until I get my tax return, but here's the list
Water Block
Swiftech Apogee - have
GPU Block
Swiftech MCW60 - have
Pump
Swiftech MCP650 - have
Reservoir
T-line with Fillport - have
With my armor coming I'm going with a res - need
Radiator
Dual Heater Core - Have but broken
I need to fix 1 of the barbs
Thermal Paste
AS5 - need
Tubing
10ft. - have
Liquid
Going distilled water with Cosworth Coolant -have
Thermaltake Armor - Bought: will be here Friday
So really the last major things I need to buy is the Radiator. The little things like the Res, Liquid, Clamps aren't as important and I can get whatever kind is the cheapest. I have 2 78 CFM fans which should be fine to get the heat out of the way since water cools better with more surface area and not how fast the fans are blowing (there might be 1-2*C difference).
Water Block
GPU Block
Pump
Reservoir
Radiator
Thermal Paste
AS5 - need
Tubing
10ft. - have
Liquid
