My XSPC dual res is causing vibrating issues! Only me?
435 Views 7 Replies 4 Participants Last post by  Mech0z
I have a XSPC duel res in my ATCS 840 case, the case has toolless installation so I am tempted remove the toolless parts and screwing it fast tight. But anyone that has this res that can report if they also have vibration issues?
1 - 8 of 8 Posts
Screw it down, I don't use the tooless things on my Cosmos S
Marcus, I've rotated my radiator now so the outlets are at the front, Looks better
Happy now?
I cant just remove the toolless parts it has metal sliding things that cant be removed, and on the right side there are no holes to screw screws through.
Iam considering selling this case and getting another (Not expensive) which has easy instalation for a triple rad and has better anti vibration featuers. Any idears?
All cases have those tabs and if you want a decent case for watercooling get a Cooler Master Cosmos S like mine, Fits a 360mm radiator in the roof
My Lian Li dont have the taps but I am using that as a server case atm. considering switching them again :S its so much nicer.
I will just have to dremel another hole in the bottem compartment for my triple rad then :s
http://www.chilledpc.co.uk/shop/imag.../v2110b_02.jpg
Just put some rubber or foam in between the reservoir and the case.
Its too tight a fight I have to thought of use violence to get it out as its sitting now.
But its alright I just have to mod my Lian Li V2110B some more, just need to find a dremel head that dont splinter all the time or just grinds down from cutting in the 2mm thick aluminium :/
1 - 8 of 8 Posts
