1 - 15 of 15 Posts
This is after playing a number of hours of Oblivion and Need for speed too! I LOVE THIS THING! Now only if my mobo oc'd well...<br><a href="http://assets.overclock.net.s3.amazonaws.com/6/64/64fa78e4_vbattach33553.jpeg"><img src="http://www.overclock.net/image/id/616806/width/525/height/525/flags/LL"></a>
well the venice core is a *tad* warmer than the sandy core (not much) but i am using as5. took me hours to get the amount right
Administrator
<div>Originally Posted by <strong>reberto</strong></div>
<div style="font-style:italic;">well the venice core is a *tad* warmer than the sandy core (not much) but i am using as5. took me hours to get the amount right</div>
</td>
</tr></table></div>
Grain of rice sized amount of AS5 generally gives the best results.<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
<div>Originally Posted by <strong>ENTERPRISE1701</strong></div>
<div style="font-style:italic;">Grain of rice sized amount of AS5 generally gives the best results.<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"></div>
</td>
</tr></table></div>
He already got that.<br><br>
@ OP<br>
Holy crap, 27C. I've never seen better temps with that cooler.
Discussion Starter #6
hers an update. All I added was a 92MM fan from my ol' Scythe Katana CU (pushes 52cfm) I added it to move some "dead air" in my case. Temps dropped EVEN MORE! God I love this thing!<br><a href="http://assets.overclock.net.s3.amazonaws.com/a/a8/a8d2e622_vbattach33800.jpeg"><img src="http://www.overclock.net/image/id/616609/width/525/height/525/flags/LL"></a>
Ha! I love my 9500 too! The thing allows for ridicoulous OCs. I also threw a VF900 on my X1800XT and its running at 738/1574. If I could cool the voltage regulators more, I think I could get a higher mem OC from it..
My idle temps were 21c when using easy tune 5, I thought they were a little low so I installed speed fan and they read 29c. Everest and pc Wizard and hmonitor all read 40c at idle. I don't know why they are all reading different temps, but i don't think you should trust that easy tune 5.
mine generally doesn't get above 32*C Usually it idles around 28-29*C
<div style="font-style:italic;">This is after playing a number of hours of Oblivion and Need for speed too! I LOVE THIS THING! Now only if my mobo oc'd well...</div>
</td>
</tr></table></div>
WOW! I sure wish my 9500 cooled that well. I'm getting 44*C at idle with mine, tho it is OC'd to 2.676. Maxed out at 100% on both cores it jumps to 54*C in just a few minutes. Can't clock any higher without better temp control. Hope to get to 2.7 eventually.
you might try reapplying AS5 or something like that because I think i put too much on which is why I'm only going 2.66Ghz at around 48C and I know I can get it a little farther.
<tr>
<div>
</div>
<div style="font-style:italic">well the venice core is a *tad* warmer than the sandy core (not much) but i am using as5. took me hours to get the amount right</div>
</td>
</tr>
</table>
</div>Actually I was told the Venice cores run cooler than Sandy cores
Mine doesn't keep my 4400 that cool. I may have to make sure that it is flat. I heard they had some trouble with them in the beginning (when I got mine). My temps stay around 54-55 with 2x FAH running 24x7.
You might try lapping as I have heard that helps but never done it myself. I'm going water cooling myself.. <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
1 - 15 of 15 Posts
