1 - 18 of 18 Posts
I'm new to mySQL and after searching in internet how to make a database finally i found how. I made a database by:
mysql> CREATE DATABASE databasename;
after i gave the privileges to the user
mysql> GRANT ALL PRIVILEGES ON *>* TO 'user'@'localhost' IDENTIFIED BY 'password' WITH GRANT OPTION;
after i did:
mysql> GRANT SELECT, INSERT, UPDATE, DELETE, CREATE, DROP, INDEX, ALTER, CREATE TEMPORARY TABLES, LOCK TABLES ON database1.* TO 'user'@'localhost' IDENTIFIED BY 'password'
after i downloaded a free template just to see if the database works. i edited this:
$host = "localhost";
$user = "user";
$pwd = "pass";
$db = "test1";
and when i restarted apache to configure the settings and went to the internet and typed my ip it came Query Failed!
What's the problem? How can i solve it?
Any help is appriciated.
EDIT: btw forgot to tell you that i'm using Ubuntu as my OS
Originally Posted by kyotejones
It would help to know what template and what error exactly you are getting.
EDIT:
usually you need to add tables to a database with columns before you can just connect a website to it.
i think that the problem is that i didn't made tables and columns :S Only the database any 1 can tell my how can i do that?
if the template is asking for a database connection, it probably also contains the table/column structure (probably from an sql dump)
he can use phpmyadmin to run the sql script (if there is one) then to later administer the data. but i doubt he can just create any random table structure... it doesn't look like that is his case.
Originally Posted by theRemix
what?
if it's localhost, what firewall do you speak of?
On your computer (hope your computer has one!).
Too often you have to access the database via a port (so true with phpadmin --- usually 3306). If your database is being accessed remotely, you'll then use an IP and port number.
BTW, one of the best ways to learn about MySQL is to install some forum software. There you can learn even better ways to connect to a database, and more securely (and to avoid some problems like SQL injections).
by default, the mysql port is 3306, you do not set host to "localhost:3306" that won't work anyway.
and if you are on localhost that means the apache server (with php) is requesting a mysql server on the same machine.... what firewall blocks itself from itself?
maybe i misunderstood you.
It's been awhile since I've been forum designing, but sure enough had to set a port (and on servers with it's own dedicated database server - IP+port). When factoring in IDS ware, more so (many times the MySQL port isn't 3306 in that setup, it's 3316 or something). Port changing is a common security measure.
yes, you can connect to localhost:3316 or whatever port, my bad.
but still, can you really block localhost (yourself) from a particular port, or all ports, in a firewall ?
Yep. Configure the IDS ware to do so (this is *nix or *bsd) -- it'll block a-n-y-t-h-i-n-g! Temp directory (common way to harden it from racing); to even the SSH port (and a wonderful way to learn how to lock yourself out!).
1 - 18 of 18 Posts
