my quad will not be stable on stock speeds no matter what volts and cooling i give it. the only thing it can now be is the N/B.
hey there, my N/B heatsink almost burnt my fingers off, hell it hurt. i think its at 60c full load. my fingers hurt even now lol. seriously. i un-did the two white catches on the heatsink put i cant seem to pull the damm thing off for whatever reason, any idea how to remove it? also this is the stability problem, it has to be, its the only thing. the heatsink was so hot it smells like its burning with a little bit of smoke. this is what is causing all stable problems.
how do i get the crap thing off? it wont budge?
also what should i buy in order to replace it? something dead cheap and with a fan, maybe a low profile or high profile thats fin.
thank you everyone, am exited to now ive found the only possible reason to this problem.
