1 - 20 of 23 Posts
Hey all.
I am trying to find pics of the "nasty" side of the TJ07 case.
If anyone has pics of their TJ07 with the cable-management side exposed so that all the wires can be seen, I would appreciate it
Oh, yeah, That's nasty!
Alex98uk, how did you route the wires for the rear 92mm fans?
Well, I can always drill, baby, drill
Drill a hole behind the motherboard. Then route the cables under the motherboard and into the rear of the case.
Exactly what I was thinking.
I am curious about what it looks like behind the drive bays. On the compartment divider, are there any holes apart from the one big one and two smaller ones, or is it solid there (above the front HDD cage)?
Thanks
Solid, but there are gaps at the front between just inside where the 5.25" bars come down, if you get what i mean. Look at the picture and see where my SATA cables come out from.
I want to do some modding on mine, but i don't know where to start.
Discussion Starter · #12 ·
Originally Posted by hiiyah777 View Post
Mine's not done yet, but this is my proposed cable management plan:
Your one-of-a-kind MurderBox does not count
It's an absolutely amazing piece of work/art.
Originally Posted by noob eater4726 View Post
@ hiiyah777: Showoff!
OMG! That's a lot of spaghetti
I like seeing the control box for the cold cathode lights sitting there. That means there is a ton of room between the mobo tray and the case panel
As most people use this case for WCing, I was wondering how this case does for air cooling. There doesn't seem to be much intake from the front to rear of the case. I would think that the rear 92mm fans would need to be changed to exhaust also.
Discussion Starter · #16 ·
Brown parcel tape FTW
Discussion Starter · #18 ·
Nice one Syrillian
Is there anyone out there using this case with air cooling? At all?
Discussion Starter · #20 ·
Do I count? Even though I'm not done yet?
No! Now stop trying LOL
Seriously, are you planning on air cooling with the MurderBox? I notice that there is a fan that directs air from the bottom compartment to the top. Also, aren't you missing the 2 92mm fans that are normally found on the back of the case?
1 - 20 of 23 Posts
